Jeep Driver
- Parrottsville
That's not exactly dialing it in.
I'm not sure how you can claim it doesn't exist, and talk about using one, in the same post.
Your claim to idiocracy is more general though.
You're the only person here who's ever used the phrase "dialing it in".
We're talking about a glorified tractor motor that appears to not have a timing problem, so if you would kindly, quit yammering on and let us get back to the OP's problem.
I am not familiar with that app. Can you cruise around and see if the ECU is in open, or closed loop?For diag "tools", I have a timing light and Torque on my phone. Any basic tests you could recommend?
I'm the one that said he had a tuning problem I'm also the one who said he does not have a timing problem
I believe it is you who has the issue
Have you driven an XJ much before? Or have a buddy to compare? Feels slow can be a pretty relative statement depending on your expectations. I mean my XJ is a dog compared to my turbo regal...lol
If he has the full version and not the trial it should. It should also be able to give him real time afr readings also.I am not familiar with that app. Can you cruise around and see if the ECU is in open, or closed loop?
Nah, I'm not chased off. I got busy with the kids sports practices and haven't had a chance to look at the XJ.
To answer some questions:
-I did reuse the stock injectors. One of the few parts I reused.
-I do have something to compare it to. I've owned a 88/4.0/5-speed w 3.55s and 32x11.5s, a 99/4.0/aw4 w 4.10s and 31s and now this 99. My last 99 would have killed this one 0-60, with it's 4.10s.
-I do have the full version of Torque. Hope to get it out tomorrow for a bit of driving.
-I may get together with some of the chapter guys on Sun to look at things (compression, leakdown, etc).
-Yes, I am in CO at about 6k feet during normal driving.
-This thing seems like it runs well. No rich smell, fires right up with no odd noises, revs quick/high, has never thrown a code.
Now, calm down boys and look at these pretty pics of the engine in question... lol.
IIRC, it has a new, 2-1/4 inch exhaust.Dont know if I missed it but how does the catalytic convertor look? Have you checked exhaust back pressure?
old_man has a vacuum gauge, and he knows how to use it.notomas said:-I may get together with some of the chapter guys on Sun to look at things (compression, leakdown, etc).
there is the problem......It,s a Kubota Tractor engine,,,![]()
