J Money
- Yorba Linda
This is just a feeler... I may want to switch to a new project if it makes sense. Please see my build thread for all the details.
http://www.naxja.org/forum/showthread.php?t=1043068&page=3
I'm looking to get 10K and I'll take 9K but I keep the front shocks. I also plan on keeping the lights.
In my opinion it needs gears and SYE.
It did pass smog a couple months ago with 190,xxx miles. Please let me know if you have any questions.
Front Suspension:
· Deaver Jeepspeed Coils
· Fox 2” Stroke Bumps
· Fox 2.5” 3 Tube Bypass Shocks (10” Travel)
· Rubicon Express 1660 Extreme Duty Track Bar
· Rubicon Express Track Bar Bracket
· Rubicon Express Track Bar Brace
· Rubicon Express Drop Brackets
· Rubicon Express Lower Control Arms
· Currie Upper Control Arms
· Currie Jeepspeed Tie Rod/Drag Link
· Patriot Fab Works Upper Shock Mounts
· Patriot Fab Works Lower Shock Mounts
· Heavy Duty Steering Stabilizer
Rear Suspension
· Deaver G9 Leaf Springs
· 2.5” 3 Tube Bypass Shocks (14” Travel)
· Patriot Fab Works Bolt In Bed Cage/Sub frame
· Custom Poly Bumps
· Rubicon Express Boomerang Shackles
· Patriot Fab Works Lower Shock Mounts/Spring Plates
· Patriot Fab Works Spring Hangers
Chassis
· Custom 4130 Chromoly Frame Plates
· Custom 4130 Frame Stiffeners
· Patriot Fab Works 1.75” Bolt In Roll Cage
· Rear Frame Rails Notched for Awesome “Gnarticulation”
Other
· Chromoly Front Bumper
· Chromoly Rear Bumper
· Detroit Locker
· Superior Axles
· Power Slot Slotted/Drilled Brake Rotors
· Goodyear MTR Kevlar Tires
· Aluminum Radiator
· High Flow Water Pump
· FF Dynamics Triple Threat Electric Fans
· 1999 Intake Manifold
· Hedman Ceramic Coated Header
· Soltek Lights Converted to HID from Baja HID’
· Auto Pal Headlight Conversion
Front Suspension:
Rear Suspension
· Custom Poly Bumps
Chassis
Other
· Detroit Locker
· Superior Axles
· Aluminum Radiator
