Feeler: complete dana 30 and dana 44
cheapcherokee93
<----boat-manche
Guadalahabra, CA
getting ready to swap in my semi built dana 30 and 8.8 into my MJ, so its stock axles will be up for sale! I'm aiming to do the front this weekend and the rear next so the dana 30 will be available first.
complete '88 D30, working disco motor, 3.55 gearing, less than 1000 miles on turned rotors and new pads. unit bearings should be replaced. one of the axle u joints would also need replacing too but since its has the smaller joints you'd probably just swap in the bigger joint shafts.
-$100 OBO, i believe someone has 89- brake parts for free including the unit bearings so those could be used on this.
then when i swap in my 8.8 the MJ dana 44 will be up for sale too.
3.55 gearing, worn out limited slip, 200k miles on it, recent wheel cylinders on it. would need new drums/shoes too. would come with u bolts and plates, bolt on upgrade for an MJ. weld on new perches and this would fit an XJ.
-$200
just gauging interest in them for now, i'll update the thread when they are actually pulled.
dana 30 is pulled and ready to go
I'm looking for a Dana 44... keep me in mind for it.
Sounds good... thanks
