aparke4
- Atlanta, Ga
great jeep: reason for sale - build a more road worth xj
will trade for stock xj - 98,99 hp 30 4x4 leather interior - less than 100k
99 jeep xj
98,xxx on body, motor, tranny
aw4 tranny - fresh fluid change 2k mi ago
np231J t case - only 35k on it (from a newer wrecked tj) with PORC SYE installed 5k ago
customer rear driveshaft with double cardon
stock front driveshaft extended 2 3 inches with DOM sleeved - no vibes until 80 mph with front driveshaft in - will go 80 without front driveshaft
4.0 I6 242
stock crossmember with one nutsert loose - tack welded until i fix which can be done before sale
dana 30 front - detroit luchbox locker, 4.56 gear, stock inner shaft, alloy usa passenger outer, stock driver outer - have driver alloy usa to install and 2 new 760x u joints - brakes serviced 7k ago - stop great lotta pad life left - synthetic gear oil - superlift diff cover
rear dana 44 from xj - avalanche engin. truss with link brackets, drums, 4.56 gear, detroit locker, synthetic gear lube, superlift diff cover - small leak at fill plug - will fix before sale (teflon tape has come off) stock 30 spline shafts
bolt pattern - 5 on 4.5 15x8 steel rock rims with 35x15x12.50 BFG mud terrains with 90 percent tread left
have matching spare with 95 % tread left - all tires still have nubs on em
custom cage rear - all 1.75 DOM with tire carrier (swingout) with unibody tie ins
rustys rear tube bumper with receiver hitch tied in to cage
chopped rear quarter panels
4 doors off a wrecked 97 - manual crank with tinted glass
B pillar - rustys roll bar B pillar with seat belt tie ins to unibody b billar
custom front dash pillars with spreaders - 1/4 steel on dash huggers and 1.75 DOM for front cage
custom tube fenders - to be done if sold
rustys stinger front bumper tied in to tube fenders
front cowl spreader
aftermarket parts and suspension:
RE 4.5 leaves in rear with 1.5 block - pro comp 1.5 lift shackles
skyjacker 8 inch coils
RK long arm from a grand cherokee lowers with daystar uppers to make a Y link design
RE braided brake lines
omix-ada rugged ridge steering HD set up
stock steering box tapped for 1/2 bolts for extra strength
drop pitman arm
RE track bar
jet stage 1 chip
k and n filter fipk intake
banks header
1 inch tb spacer - smooth bore
bored tb to 60mm
magna flow cat
flowmaster muffler 40 series with 2.5 pipe from stock downpipe to exit
always used k and n oil filter and castrol syntec 10w30 oil
MORE bomb proof motor mounts
custom LED lights in rear
panasonic mp3/ dvd headunit (a 500 dollat unit) with flipdown screen - needs power hooked up and works great
jenson 6.5 front speakers
alpine 6.5 rear speakers
4 point harnesses with APC racing seats
herculined interior
hi lift jack
rear YJ seat needs installed
optima red top battery
3 core HD radiator
rock it parts hi flow therm housing
hood vents
overall the jeep is great - not pretty in some aspecs but needs so TLC - the running gear is awesome and the motor is flawless - comsetically it needs some help and thats about it - i was about to paint in all black so for now it is a mix of colors
pics to come later here are a few old ones
oh skid row tcase skid - 2 pro comp 55 driving lights and 2 european made light housing w. silverstar bulbs tied in to factory lights
old pics
99 jeep xj
4.0 I6 242
front cowl spreader
drop pitman arm
RE track bar
jet stage 1 chip
banks header
bored tb to 60mm
magna flow cat
herculined interior
hi lift jack
3 core HD radiator
hood vents
old pics
