Feeler: 90 XJ Lifted 4.0 AW4 4x4
offroader461
peoria, arizona
Im checking the possible interest on my XJ...finished up with the MJ and really dont need it around anymore. Here are the specs on it
1990 Jeep Cherokee
4.0L 185K
Aw4
Np231
D30/D35 (will toss in locker for rear)
Lift:
Rancho 3" springs
Daystar 1.75" spacers
Rancho LCA
Superlift adj trackbar
ZJ steering
RE 3.5 full leaf packs
RS9000's on front with BPE
ES3000's on rear with BPE
Other things done:
CB w/antenna...needs wired but installed
New cooling system: OPEN SYSTEM CONVERSION DONE!
-water pump
-3 row aluminum radiator
-Hi flow thermo housing
-Upper and Lower hoses and heater valve
-new overflow tank
Push bar on front bumper
Factory tow hooks and brackets
4-32*11.50 R15 BFG A/T on Black Rockcrawler rims (rims warrantied)
1-32*11.50 R15 Kumho M/T on same rim for spare
Resealed valve cover, oil filter o-rings and distributor gasket
Poly motor mounts
New trans mount
TJ fender flairs
Pioneer CD player and pioneer speaker up front
Newer door panels
Tinted windows
Gibson exhaust (rattles b/c they gave me the wrong style)
99 XJ mirrors for better vison
99 sway bar and endlinks (1 1/2" longer to compensate for lift)
IAC, TPS, CPS all have been replaced
Plugs, wires, cap, rotor all have been replaced
Brake switch conversion (will explain to anyone wanting to know)
TAGGED TILL 2010
*Changed the oil, trans fluid, f/r diffs and t/c fluids all within the past 2months
Asking $3400 OBO if anyone is interested just PM ME or call 623*628*3330
Here is the most recent pic: Light bar on roof not included
