fast question on XJ???
cbert1234
Michigan
I have a 91' cherokee limited, it has the smallest rear, I blew the rear end about 2 months ago, got one from a junk yard and its up and running just fine, my problem is now in the front end, the front axle is leaking fluid out the end of it on the passenger side of the axle, it is a pretty good amount of fluid too, I'm wondering if I should try to buy a new axle or do the junk thing again, does anyone know of a website to buy new front axles???I went to Rustys and looked at the 3" lift, I think I'm going to raise it the 3", will that affected the axle???any help would be great!!!thanks
If it's just leaking, that means a seal. If you needed a front seal on the engine, would you replace the entire engine, or just stick in a new seal?
I'd go for the new seal.
