Fan clutch re-hash......
The heater core has a constant recirculating supply and return thru the engine block and t-stat housing bypass so if your not seeing any heat you would have a different issue.
As I mentioned before, there seems to be wide range of how any fan clutch acts. I see differences in the stock clutches right out of the box, some engage harder (louder) and pull more air.
With the ZJ clutch, I ran it for six months, starting in the summer and removing it in that winter. It worked great for that summer's wheeling trips.
With a 425 weekly commuter mileage, driven at night when the traffic was light, I was able to track fuel usage before and after the ZJ clutch, there was a drop in mileage and, like Ehall, on very cold winter morning, it took forever to warm up.
And yes, the thermostat was a 195 degree.
Once the stock clutch was reinstalled, it warmed up normally . Having the fan partially engaged all the time provided too much cooling air when the engine was cold
YMMV
As i said my NAPA ZJ clutch fan did nothing at all for Summer cooling.
These 2000/2000 XJ's just run hot probably for EPA reasons.
Forget using AC in hot Summer stop 'n go driving.
This Spring gonna go back to a stock clutch fan and rely on my efan over ride timer as i had to do with the ZJ clutch fan.
Maybe i'll even add a thermostat to automatically turn on the efan.
We'll see.
Yes, I still don't get any of the noise that everyone talks about but it definitely dropped the coolant temps by about 5*. My engine now runs about 205*.
That would definitely apply to my Jeep, I run braided hoses on everything. The transmission and cooler, the power steering and cooler, and all my fuel lines, and now my pre-oiler pump.
Do you have an sort of writeup you did on converting the tranny and PS lines to braided?
Do you have the clearance issue between the fan and radiator with the "non HD" unit?
