martin
- Huntsville, AL
Everyone,
I just wanted to say my 88 XJ electrical troublshooting manual had the information I needed to hook up a trailer brake controller. I was trying to find where to get a continuous 12 volt. I did not want to run another wire to the battery POS terminal.
I read the manual and found where the factory tow kit got the power for the tow kit. The factory installed a 30 amp circuit breaker on the fuse block and fed the trailer circuit. I decided to see if that terminal was on my fuse box, sure enough it was and it was hot with the switch off!!!
So in the next week I'll install the brake controller and run 12 inches of wire to connect the controller to 12 volts and a like length to attach to the dash board ground. I also found the ground for the dash board from the manual.
I just wanted to make the case for purchasing the factory manuals for your XJ, jobs like this they are worth what you paid for them 10 times over.
