Experience a cam failure? Me too.
Hmm.. to make matters worse the post I was referencing isn't even on this, but the co4x4 board, that'll confuse a guy.
I hope you get it figured out, this stuff is the pits. I had a somewhat similar problem, but mine was the plain journal cam bearings- gone in 100 miles in my 401. Lobes were still good. I was considering Velcro motor mounts.
Frank Z said:
We then pulled the pan and once again I was expecting a thick silvery coating on the bottom. While there was evidence of metallic dust/oil it was not nearly as bad as we thought we'd see. YES!!!
If you still have it, cut the old filter open. Racers do it to check what's not going to the pan - a standard 10 micron filter does catch a lot. It's what you want it to do.
I'm experiencing a collapsed lifter from carbon grit lately. Next change I'm opening up the filter to see what's in there.
At work we use a cutter like this. I'm not saying to go out and buy one, you could probably make your own, like we did, for alot less. Just don't use a saw and add a bunch of metal as you cut.
~Alex
