Exo/int cage and boatailed
garomy
My new addition to the xj.
front
Choped the rear, move the fenders in +- 4" on each side. open the wheelwells, aded the exocage with an interior rollbar attached to the exo trouth the roof.
Wow, nice job, clean rig.
The front fender bars, through the clip to tie in the bumper looks great.
Is the B-pillar attached to the halo through the roof??? Any close up pics?
All that tubing and still a bent tierod..... just messing with you.. looks nice!
Also, Go the the SE forum or on the main page and bring it up to the Cherokee Crawl next week at Tellico...
It may need some triangulation front to back altrought it is way strong considering that the exo is tied from the rear bumper to the front bumper under the front fenders ( ala Gotan )and to the rollbar inside the cab throught the top with plates "sandwiching" the roof..
I will be at Tellico next week, hope to see some of you up there.
what vehicle is your best top from? i have done the same as you with the back and am looking for something similar to that set up...
Does the soft top work with the cage now?
What kind of interior cage is it? Looks like its just a hoop for the B-piler?
Did you tie the cage into the frame? Hows that attached?
On the interior is only a rollbar connected to the hallo with a plate on both side and bolts throught the roof, and welded on the floor directly to the unibody.
That will give protection and plenty of room on the inside.
The leather top is from a yj, and it will be modified to fit under the hallo and over the back seat.
The spare tire and high leaf will be mounted to the bar behind thew back seat.
