Tyj99xj
- Cashmere, WA
I have a '99 XJ w/ blown motor and a '90 MJ, both with the 4.0L
The 4.0L in the MJ is a HO because it was swapped with all the wiring from a '93 XJ, now I am looking to rebuild this motor.
Here's my question, if I go about rebuilding the '93 HO will I be able to use all of the wiring/sensors/dash from the '99 in my MJ?
Basically, I want to rebuild the '93 motor, and while it is out swap everything from the '99 such as dash, interior, wiring, etc. Once the '93 motor is rebuilt can I just drop it in fire it up or am I going to have to do a bunch of work with the connectors and everything? Any help would be greatly appreciated.
