8Mud
- Central Germany
I´ve got a Renix CPS, that tests good, 210 ohms of resistance out of the vehicle cold.
Thinking what could be wrong with this bugger. Seems like with the resistance, it has a winding of some type in there. Actually with the core magnet in it, it appears to be a small generator.
Magnets get tired and old trick to get tractor generators (like alternators but older) going again was to flash the field with 24 volts, to remagnatize the field magnets.
If I figure out if it´s possible or not, I have a flexplate out of an XJ, to set up a test with, on the bench and see if the generated voltage changes with a flashed magnet. More, less or none.
Next question, it´s been so long since I flashed a generator magnet I can´t remember if polarity was important or not.
A hint at the amount of voltage that may be tolerable and still do something would also be helpfull. Also the voltage that would just turn it into a fuse or a one time lightbulb.
The worst that could happen is I turn my questionable CPS, the old one from a recent replacement, into total junk.
It´s possible, I think to flash the magnet and put some new life into a CPS, while probably not a fix, something to get you home in a pinch.
We may stumble onto something, that may be a boon to XJ kind.
