my2monkeys
- Mission Viejo, CA
Stuppid question ,but why doesnt the fuel pump being immersed in fuel just short out between the pos. and neg. terminals ? Does gasoline conduct electricity?
fizassist said:Gasoline has a low electrical conductivity, but more importantly, all electrical connections are insulated from the gasoline.
TJ Rat said:Gasoline liquid does not burn, it is the vapors that do.
We had a demonstration from the local fire department. The fireman actually put a match out in a cup of gas (he knew what he was doing).
So long as the connections are connected and there is no arcing all should be OK.
5-90 said:Yep. Road flares will go out when kicked into a Diesel spill as well (had a cop who didn't know that while I was getting a roads incident under control. I was putting flares out, he told me that was a fuel spill, I said "I know - it's Diesel" and kicked a flare into it.)
As long as the electrical connections are tight (they're usually screws and ring lugs,) you'll be fine. You just don't want any sparking - especially with a low fuel level...
garr said:The fuel pump & connections are submerged in fuel.
Simple, No Oxygen=No flame, I learned that while working on aircraft & noticed all the fuel pumps were in the fuel tanks!.
rockwerks said:cherokee electrical connections are simple clips no screws. just press on connectors
fizassist said:Gasoline has a low electrical conductivity, but more importantly, all electrical connections are insulated from the gasoline.[/quote ] OK, thanks for the responses, so if I dunked the fuel pump in water and put 12 volts to it would it blow a fuse or work just fine? Also, if I put my head lite in the fuel tank and turned it on, what would happen? Thanks for your thoughts.
bjoehandley said:I'd have paid to see the look on his face when you did that:laugh3:
rockwerks said:hello even when the tank is 3/4 full on an xj the connectors are above fuel line
