Bender
- Cambridge, Ontario
I've been playing around with my stroker trying to get the optimum performance and was curious as to your opinions on an idea. I'm running the renix based style stroker with injectors that flow 22.7# at 39 psi. I have a MAP adjuster but haven't had to use it. I'm only using the plug colour to determine if it's running rich or lean...not very accurate I know.
I was thinking of raising my fuel pressure to approx 45-49 psi and using my MAP adjuster to compensate if it happens to overfuel. I figured I'd try and make use of the so called better atomization of the fuel when sprayed at higher pressures.
Any thoughts?
I know the 4.0L ran 39 psi up until about 1995 where it switched to 49 psi so I don't see any real problems since jeep ran it above 39 psi stock. I've also noticed several high performance vehicles run higher pressures in the 55psi range.
Any thoughts?
