- 29°58'28.9"N 99°15'15.5"W
Educate me d Apple Notebo`s
I need@ro buy Lp snn a Apple bte book.
I know nothing about them.
Educate me.
Educate me.
jeeplas said:Who told you I ate an I-pod?
I have to disagree with that. The switch to x86 is a real big jump for Apple. And some software doesn't work on both platforms. If you're a software company and you're writing new software then you're not going to worry much about backwards compatibility to the older CPUS, you're just going to code for the x86 models and put it as a requirement on the box. This is the same sort of architecture change that Apple went through when going from the 040 line to the G series. At the time the "velocity engine" was all the rage in the G3. It didn't take too long for all software to require a g3, about 18 months. It pretty much made all of the older 040 macs worthless if you wanted to keep your software up to date.cowboybarber said:I believe it will be quite a while before the Powerbook G4 becomes obselete. If I were going to purchase an Apple laptop, this would be my first choice, unless money is no object.
First thing is make sure you want an Apple period. They are great computers, but sometimes finding the software you need for them can be a pain. Windows PC's are more crappy but the software is readily available.
