Ecm keeps going bad. 96 xj
I was think that ( short in harness) or the alternator regulator part of the ecm burning it out because of the alt. But the short in the harness/ bad plugs is more likely.
Can't read it with a scan tool. When the ecm fails it dies all at once no warning signs at all. When it dies it just cranks. I was wondering if it was a short. I'm new to the Jeep world was just wondering if I was possibly looking over something. Or if it was a common problem.
To many (most) of the sensors the ECM supplies a voltage lower than battery voltage. Typically 5 volts, but sometimes a little more. The sensors supplied are grouped (a sensor loop), anywhere from a couple to half dozen sensors.
Typically the Check Engine light you see when you initially turn the key to the run position, fails to light at all if a sensor is shorted. The check bulb at start stops functining. Which usually indicates a shored sensor or a partially shorted sensor. The ECM shuts down to protect itself.
When the Check Engine Light fails on my 96, I unplug sensors one at a time until the light (CEL) comes back on, when I turn the key (initially) to run. You remove the shorted or partially shorted sensor from the loop and often the ECM will function again.
Someplace to start, unlikely to help if the wiring is shorted, the power to the ECM is flaky or a ground is bad.
Usually when an alternator fails the voltage regulator part of the ECM will fail, it seldom affects the rest of the ECM functions. The exception being reversed polarity at the battery or a serious voltage spike.
Low voltage is usually temporary and doesn't hurt anything long term.
Don't confuse an ASD relay issue with a sensor or ECM issue. I found a flacky connection under the dash near the gas pedal that would sporadically de-energize my ASD.
Just some ideas.
yeah.. Jeep ECU's are pretty hardy against shorts and it takes a lot to actually kill them.
As suggested above, it just may be a case of a bad ground or a faulty sensor grounding the 5v reference causing the ECU to go "brain dead." Once the cause of the short is corrected the ECU will return to normal.
Replacing the ECM is the last thing you should do, I have never found a dead one.
Since the Jeep started working when you replaced the original computer, I would suspect a bad plug, a broken wire or another defective electrical part.
If the computer has not set a code, scanning it with inexpensive scanner will not show anything.
Get a FSM and use the wiring schematic and plug pin-outs to trace the wiring. This isn't an easy process but it's what needs to be done.
Welcome to the world of antique Jeeps, be happy that the electronics are relatively simple compared to modern cars.
