RichP
- Effort, Pa
5-90 said:Kinda like the early difference between IBM PC's and Apple computers - going to the "open" architecture allowed IBM to give Apple a thorough clobbering in the market - and they're still recovering (note that the PowerPC/PowerMac finally adopted the PCI bus, and they've probably finally caught on with AGP as well. I also find it telling that Apple offered Intel's USB before their own FireWire/IEEE-1384...)
5-90
Partly true, both apple and ibm went propriatary bus, ibm went micro-channel and when the powerpc came out in ahhhh, ~96/97 it was sold under both the IBM and apple labels and ran AIX/CDE, even now you can install AIX on the apple branded ones and you can run the apple OS on the IBM ones. IBM's microchannel architecture was licensed, if you wanted to build cards you had to pay IBM a fee and they would give you a block of numbers the chipset on the board would recognize which meant you had to pay for how many cards you wanted up front, very unpopular for the video and modem companies, one reason external modems hung around in corporations for so long, IBM could not really lock down the serial ports. A compay in SanDiego Calif, Regal, built IBM microchannel clones, to even replace a HD you had to buy it from either IBM or Regal, they had a string in the HD firmware that the system needed to even see the drive and the drives cost 2x the normal price, 500meg Conner drive was $600 vs the same drive at compusa for $250. Hence The 'Gang of 7', Gateway, Dell, Packardbell, etc got together and devleoped/accepted a standard ISA, VESA, EISA and later adopted PCI standard they all decided to build to, ticked IBM off no end. Even to this day IBM uses Micro-channel though in a limited number of systems.
