8 88XJScott NAXJA Forum User Oct 19, 2005 #1 I am running 6" of lift and waggy axles, I need some ebrake cables, but I'm not sure where to get them and which ones to get. Any body have any good ideas? Stock cherokee ones are to short...
METAL MONKEY NAXJA Forum User Location severance, co Oct 19, 2005 #2 2 passenger side cables from a 95 yj will work. do a search, and you'll find some part numbers.
ECKSJAY Water is dirty Location Covington, WA Oct 19, 2005 #3 Fuel90 said: 2 passenger side cables from a 95 yj will work. do a search, and you'll find some part numbers. Click to expand... Normally, but he's running Wagoneer axles...which may be different. Scott, get ahold of MORE (http://www.mountainoffroad.com/more.htm), they should be able to help you out. Probably the baddest cables I've dealt with.
