ds drop toy axle
Rob707
sacramento
Front ds drop toy axle, 4.10's, spool, highsteer, all new bearings, set up for 3-link and coilovers, trussed, plated on bottom, tacoma rotors, ifs 4 piston calipers. Coil buckets could be put on to run coil springs, 59.75 width. 600.00. without shafts o r1200.00 with 30 spline longfield shafts.
why are you selling?
Pinion is rotated up 6deg and caster at 10deg
why don't you just keep that housing and run the third member from the new front end? or can you not do so?
really they are that big? WTF? so the FJ80 is pretty bad then? wow. the d60 joints make a d30 760 joint look like a tiny little kids toy, or a sector shaft u joint
yeah they BIG.
hard and expensive to get parts for but when they're that beef who's gonna break em?
Rear axle is a work of art; full float, 30 spline, 9.5" ring gear, e-locker, disc brakes.
but not all of them had elockers, no?
Sounds like a beefy setup...
Also included in the price is a 3rd gen toy rear with a open 4.10 carrier thats set up for a 4 link or cut off the brackets and put on perches. Buy the brackets for front coils and rear leafs and i can put them on both front and rear axles
