1 1SIKXJ NAXJA Forum User Location garland tx Nov 27, 2009 #1 will this do any good or bad if i get a 3 inch drop pitman arm
Exxon Valdez Jeep NAXJA Forum User Location Temple TX Nov 27, 2009 #2 If you drop your pitman arm 3" you also need to drop your trac bar the same. They need to be parallel to each other, otherwise you get bumpsteer. A ZJ pitman arm gives a 1" drop, btw, and the bumpsteer was noticable to me, I took it off.
x2elite NAXJA Forum User Location Texarkana, AR/TX Nov 28, 2009 #4 I use a zj pittman arm and a crossover steering setup, and it works great.
wheelinscott NAXJA Forum User Location Ogden Nov 28, 2009 #5 what size lift are you at to need that big of a drop?
