drop pitman arm
If you drop your pitman arm 3" you also need to drop your trac bar the same. They need to be parallel to each other, otherwise you get bumpsteer. A ZJ pitman arm gives a 1" drop, btw, and the bumpsteer was noticable to me, I took it off.
I use a zj pittman arm and a crossover steering setup, and it works great.
