Just got done, 2 hours total for both sides counting BS time, started at 6:30pm, finished around 8pm. Parts store delivered the wrong universals so warren pulled a precision gear set out that he had squirrled away for his J10. I can see where taking apart could be a major PIA in the driveway. Once up on the alignment lift I got tires, calipers and rotors off used a 3ft 1/2 breaker bar w/1/2" adapter and a 12 point impact socket to break the 3 bolts loose then used a wrist breaker air ratchet and I mean a wrist breaker, this baby wouldn't stall
then put the bolts back in about 8 turns, grabbed and air hammer and used a special bit that looks like a socket but has no points, fits right over the bolt heads, 10 seconds on each bolt and the axle flange about fell out. The universals were shot, one was pretty broken up on the drivers side, the passenger side pin bearings were nothing but a rusty memory. The biggest PIA to me was getting the old C clips off, they were pretty rusted on but a few blows with a hammer on each end cap freed them up. Cleaned everything up with a 3m pad in the air grinder, copper anti-seized the whole thing and reassembled. All in all, not bad WITH THE RIGHT TOOLS, would not want to do it in the driveway unless I had it apart within the last 2 years, getting under there with hammers and slide hammers, nope. Oh, I did not remove the axle nut, cotter pin, took the whole assembly out. Learned alot so it was a good evening...
Even learned a trick for getting those damn caliper bolts to line up, I've always wiggled the caliper, tried lining the holes up with a small phillips head, found out tonight the I need to WIGGLE THE FRIGGING ROTOR and they pop right in. Like I said, it was a good nite.... :sunshine:
