cloudswimmer
- So.Cal.
Does this angle between the pinion yoke and drive shaft look bad?I was told I have a driveline vibe by a fellow XJ'er, and he looked at it and said I need between a 4-6 degree shim.Only thing I've noticed is a drone sound at fwy speeds that I always equated with my Magnaflo exhaust.Also when the back of the rig is loaded down with camping supplies, mining and auto tools, etc. the rear sags, so doesn't that change the angles too?Just don't want to cut off my ladder bar, raised shock mounts, grind down, shim, and re-weld if its not toooo bad.Its a J.E. Reel CV shaft with an Advance Adapters short shaft kit.
