JBrobeck
- Cottage Grove MN
I am wondering what kind of drivability I can expect out of a set of 21 or 24lb injectors, on an otherwise stock 4.0L. Reason I am asking is that my injectors are pretty shot, and starting to leak (at the body itself, not the o-rings) and I am going to be building a stroker come mid summer. I figured rather than buying 2 sets of injectors (one set for now and larger ones when the stroker happens) I would buy a set of ford motorsports 21-24lb injectors and use an adjustable fuel pressure regulator to tone them down a bit if necessary till the stroker motor is built. Have any of you out here in 4.0L land done such a thing, and what were your results?
