xcm
- Southern Oregon
Less typy, more drilly.
Play around with it, you'll figure her out.
What weld process, what filler material?I discovered something else I need to figure out. Drilling through weld.
A good example is filling in some holes in plate that needed to be redrilled.
Any suggestions?
Thats kind of interesting because in the informal reviews I've seen the Champions didn't do any better than the Norseman. Did you try the Norseman? If you think they're better than Norseman I may give them a try.
Was there any discoloration after the first go-round with the grinder?I was using too much pressure when grinding. I reground the surface and was able to drill it fine with regular HSS bits.![]()
following this thread.
I ordered some Norsemen bits to try out.
I usually just buy the 15$ milwaukee sets for cheap bits since I use the small ones for pilot holes and just burn through the 3/8 and 1/2" bits in those kits for all the misc fab work.
(and single milwaukee for 9/16, 5/8.. 3/4) , i grab 3-4 sets at a time, and just run through them and buy another 3-4 sets. I have a 1.5HP drill press that I use for most stuff and a low speed high torque drill that will break your wrists if you dont respect it. for the rest, a milwaukee corded drill or my fuel cordless drill.
