Scrubber3
- North Carolina
Recently I installed a 3.5 inch lift and 33 13.50 15 on steel pro comps on my 01 XJ. When I did the lift, I swapped the D35 for a Chrysler 8.25 with traclock. Upon test driving it, there were some noticeable vibrations when accelerating. Decided a transfer case drop was in order since I don't have the time or money for an SYE just yet. The transfer case dropped did the trick. Figured while I was at it I'll go ahead and adjust the steering stops and install extended sway bar end links. Next I need to get an alignment, but before that I was wondering if I should do anything with the track bar. Drill out the lower bracket towards the driver's side about 3/4 of an inch or just get a new track bar that is longer? I'd like to just leave as is and go get an alignment, but id hate for it to dog walk after the alignment and just end up having to do something anyway and wasting the money. I'm sure someone here has been in this position before. And help would be appreciated. Here is a picture. Or two
