afd516
- Fort Worth, Tx
I aquired an extra np231 transfer case with a sye on it when I bought my xj. I was going to just swap transfer cases but the one I aquired has a 23 spline count input and mine has a 21 spline count.
So, I removed the sye from the spare TC and cut the shaft on my original. I have the hole drilled out to 5/16. I think it needs to be a bit bigger, but I do not want to drill any further until I find out what size the hole should be. Also, what size tap should be used? Does it matter? Can I just drill it to the size hole I want and tap it for any standard bolt? :dunno:
BTW, I searched and :read: for this info but it is like trying to find a needle in a hay stack.
