bchulett
NAXJA Member #999
- Southern California
I've changed a Crown Vic with 105k, Mark VIII with 128k, Escort with 110k over to synthetic with absolutely no change in oil consumption or leakage. And it was Mobil 1 0W-30.
I think mine was a coincidence... not blaming the change to synthetic for the leaks... especially since XJs are known for leaks coming from the RMS, Oil Filter Housing, Valve Cover and other known sources.
I simply don't like changing stuff like this when anything can tip the scale...
On the bright side, I have really good oil pressure 30-50psi (especially since I ditched the Fram)... and burns the same quart of oil between changes since it was new.
It's close to turning 170K miles... the motor has never had surgery.
