bugout
My XJ came with a 3" RC lift. The RC lift brougt the rear end up with an add leaf and the front with new lower control arms. springs and shocks. I put 31" AT tires on it. The rear end has a shim but I'm not sure how many degrees. I removed the rear sway bar. It rides fine. The only time I get any vibrations is at speeds over 70 which are minimal and I'm sure are normal. It tracks fine at those speeds also.
I'm trying to get higher on the cheap. I'm not too worried about articulation or tire rub because where I live there is NO landscape. Mud and DEEP water on the roads are what I contend with the entire rainy season. It's not a DD but I need it streetable.
Can I use a 1" lift shakle and 1" coil spring spacer to get another 1" of lift WIHOUT a SYE, which defeats the "on the cheap"? How many degrees is it safe to shim the rear end or is recommended?
Correct me if I'm wrong.
Stock tires size on most = 27" so 31" tires get me to about +4"
RC 3" lift = +3"
+ or - 7" so far???
96 Country, HO w/0630 head, AW4, NP231, D30 front, C8.25
RC 3" lift = +3"
+ or - 7" so far???
