Ecomike
NAXJA# 2091
- MilkyWay Galaxy
5-90 said:Interesting. Given the same construction, the torque output of individual engines becomes a function of crankshaft speed (assuming same head/cam/breathing/...)
I get best mileage cruising at 2800-2900rpm crankshaft speed with 31s and 3.07. I still want to change the gearing (it really doesn't sit well with the transmission, it's a horrible complement to the tyres as well...) and that should end up changing the relationship between cruise speeds and crankshaft RPM - I'll have to find my notes.
However, if you were to do a longer-term test to find your "sweet spot" for crankshaft speed at cruise, I'd like to see your notes when you were done.
I did some limited tests already using the AW4 like a manual tranny running it at different shift point rpms on stop and go driving. At 1,400 rpm and 3,000 rpm, with 235R75 15" tires and 3.54 rearend the mileage dropped to about 10 mpg. Actually it was worst upshifting at 3,000 rpm, and not much better upshifting at 1400 rpm. I find it interesting that now that I have the TCU wires all working and a new properly working, and well wired (good grounds) TPS, with all the other sensors pretty much dead-on per the FSM, that at 10% to 50% of WOT the TCU upshifts at 2000 to 2200 rpm, and the next gear kicks in at 1800 to 2000 rpm. A very tight rpm range from first to fourth gear while the TC is still unlocked and while running in D. If I push the throttle harder to say 75% of WOT the rpms shift a good bit higher, but gas mileage suffers.
I suspect your rpm sweet spot is so high due to the gearing and tires. From what I have read here you really should be running something in 4.x gear range with those tires.
What kind of mileage are you getting anyway???
