BLUTO
- Holly, MI NW of Detroit
I did a search, but couldn't quite find what I needed for disconnecting & removing the ABS system on a 2000XJ. I looked over Haynes manual and my 2000 FSM. The 2000XJ is a different layout than the earlier (late 80's - early 90's units). The FSM didn't even go into hydraulic circuitry in much detail :dunno: . I removed the ABS relay and fuse and bleed the brakes (no avail), needs a lot of foot pressure to get brakes to grab. FSM says to bleed ABS using a electronic monitor/control box, because air gets caught in the ABS pump during axle changeouts. It also said that during "normal" braking operation (non-ABS) only the MC, proport. valve, and booster are operating.
Q) Has anybody sucessfully removed their ABS on a 98' or newer XJ? Does anybody have any hydraulic flow diagrams from MC to ABS pump/HCU? (non in FSM)
Thanks,
BLUTO
Thanks,
BLUTO
