Disassembling steering column to fix damage
bigalpha
Moderator
Tucson, AZ
Some asshole stole my Jeep and jacked up the steering column surround. I don't think there's any unfixable damage in the column.
I think that I only need to replace the surround, and the spring. Is there a good steering column disassembly write up? What about diagrams or pictures on how this is supposed to look?
Have you considered just grabbing a used column from the recyclers?
Yes, swapping the column is probably the route I'm going to take. I just wanted to keep my options open.
Swapping the cylinder doesn't require a steering wheel puller, right?
depending how stuck your steering wheel is, It'll probably require a steering wheel puller and a lock plate remover. I've gotten lucky before and had the wheel pull right off, but starting without it almost guarantees it's need.
Yeah, I suppose it's best to have the steering wheel puller when I start. You're right - if I start w/o it, then I'll definitely need it!
