tigerchief
- here
just fyi this would not work on my 2000 with coil packs... the a/c compressor hit the coil pack....
Wut? Explain further please...
I did notice that on one of the customer installs I did, as soon as I get some time I plan to redesign the upper mounting to fix that issue and notch for the steering box. I hope to also have baffle in between the fans.
I wired the drivers side fan to the factory harness so the PCM controls it and doesn't throgu the check engine light for fan failure.
I did it to preclude the PCM freakout.
It's my wife's DD, so it has to be automagic and redundant or she will break it.
87manche...
Just re-reading this thread since my DB kit came in the mail yesterday and I'm trying to prepare to do the install in the next week or so.
Are you saying you wired in 1 of the 3 fans to the OE Electric fan so that the Jeeps Computer doesn't throw a check engine light and it's controlled that way? So the remaining 2 fans are controlled via DB's kit and controller that is inserted into the top heater hose? Just trying to visualize this before I tear my rig apart and then don't have parts I need. (Done that way too many times and then had to get a ride to the parts house f/a friend or wife)![]()
If it didn't have the heatsoak issues I would have ran the fan controller to a key on 12V source in the PDC. It doesn't take a bunch of current. You could easily tap into the fuel pump relay or the ASD relay in the PDC and keep it clean.
