Okay everyone, so I have searched, and found a lot of info, I would like to have it all in one thread, plus I have a few symptoms that I would like to toss out there that I didn't see in other threads.
I have a 1999 xj, with 99,000 miles on it. It has a four inch "Bastard Lift" and is strictly an on road machine. I use it to plow snow in the winter. After the lift went on, I had death wobble. I was corrected by having an alignment done at my local Conrads. The only thing that I have done since the alignment is go form the factory 215/75/15's to a set of 225/75/16's from a Jeep Liberty. The tires are brand new and balanced properly. It ran and drove fine for about 1000 miles after the new tires and wheels, but suddenly the death wobble is back and worse then ever. It happens at any speed above 30 miles an hour and 95% of the time it is while I am making a small curve either on the highway or on any of my local streets. I have spent a lot of time under the front end and can't find anything that is loose or worn.
My question; has any one encountered this exact problem, and if so, how was it corrected. Also, any other death wobble issues, what did you change or fix to correct the problem. I should still be okay on the alignment even though I when to a slightly taller tire and wheel right?
