Dana 60 full float axle seal?
XJRN
Indiana
I broke my drive shaft yesterday and limped the jeep home in front wheel drive. When I got home I found this. Could I be expecting any other carnage besides an axle flange gasket? They are yukon shafts with only a few days on them. I will tear it apart later but wanted to see if something else could be wrong.
Flange bolts are probably loose. I've noticed after building a couple FF rears, the bolts need a retorque after a little use.
Man that would be nice if that is all it is.
I might be prone to use a bit of Loctite if they loosened up.
