Dana 44s and stuff
GordoSmasho
Nevada Raisins
So I had all these plans but they changed now I need funds and to get rid of stuff.
For sale
96 Isuzu rear dana 44 factory disks with factory ebrake cables 4.30 gear set. 6on5.5 - $200
Motive gear 5.13 rear dana 44 gears NIB - $100
Motive gear master install bearing kit NIB $80
Detroit trutrac LSD 3.92 and lower NIB $350
89 wagoneer front dana44 drivers drop complete with factory steering 6on5.5 unknown ratio - $150
4- 15x8 black crawler rims 6x5.5 - $80
whats the backspacing on the rims?
They are 4.75 back spacing.
I also have set of 15x10 5on4.5 black street lock crawlers with 3.75 bs they are a little roached but still work and hold air. $60
4.75" for sure? thats pretty deep. if you're 100% sure I might take them and just see if they clear my brakes and my knuckles.
oh crap nevermind. I was thinking they were 5 on 5.5, not 6 on 5.5, doh, nevermind. I need 5 on 5.5 with 4.5 or 4.75" back spacing ideally. already have some with 4" backspacing.
Bump for some changes and price drop
96 Isuzu rear dana 44 factory disks with factory ebrake cables 4.30 gear set. 6on5.5 - $150
Motive gear 5.13 rear dana 44 gears NIB - $80
Motive gear master install bearing kit NIB $60
Detroit trutrac LSD 3.92 and lower NIB $300
89 wagoneer front dana44 drivers drop complete with factory steering 6on5.5 non-disco 2.72 ratio - $150
4- 15x8 black crawler rims 6x5.5 4.75 back spacing - $80
4- 15x10 black simulated beadlocks a bit roched but still work and hold air and are true. 5x4,5 3.75 back spacing
$50
Factory rear skid 97+ $40
Tow bar class 4 $40
Factory rear bumper black with mounts 97+ $10
Barely used cat conv- $20
Cat bolt in, or universal?
96 Isuzu rear dana 44 factory disks with factory ebrake cables 4.30 gear set. 6on5.5 - $100
wagoneer front dana44 drivers drop complete with factory steering 6on5.5 non-disco 2.72 ratio - $100
$50
Tow bar class 4 $40
$50 ***SOLD***
Factory rear skid 97+ $40 ***SOLD***
Tow bar class 4 $40 ***SOLD***
Barely used cat conv- $20 ***SOLD***
I'm almost tempted to pick the axles and wheels up to put in my mj. But money and distance are far.
4- 15x8 black crawler rims 6x5.5 4.75 back spacing - $80 ***SOLD***
$50 ***SOLD***
Sent from my iPhone using Tapatalk 2
I honestly thought the axles would be amongst the first to go. But I guess they are the last.
200$ gets you rear disk and 44s front and rear. Gears mounts steering and done. Both axles were in running condition when pulled just been sitting for a bit.
Payments ? Free delivery ? Ha
if I wasnt too busy blowing money on my jeep id buy this axle just out of principal. 4.30 gears, 44, rear discs? wow. throw lunch box in, re gear a front end to 4.27/4.30, and call it done...
I doubt the mounts are even correct as is, but are these set up spring over or under?
Also, do you know if the axle shafts could be redrilled? Other D44 shafts fit these?
If you are willing to do some sort of payments for it/can hold on to it til I can get up there or parts train. Let me know. I need an axle for my MJ, and figure this would work quite nice.
