K kirby NAXJA Forum User Location South Weber May 28, 2004 #1 What is the strength difference if any between the dana 44 6 lug and the 44 8 lug from a chevy?
BrettM NAXJA Forum User Location michifornia May 28, 2004 #2 no strength difference where it counts, shafts and u-joints are the same
K kirby NAXJA Forum User Location South Weber May 28, 2004 #3 Is it possible to convert a 6 lug to an 8 lug very easy?
basalt51 NAXJA Member #761 Location Woodland, CA May 28, 2004 #4 kirby said: Is it possible to convert a 6 lug to an 8 lug very easy? Click to expand... I believe depending on year, you just need to use the 8-lug hub/disc assembly. If you have an older chevy 6-lug with the smaller bearings (early '70s?) you'll need to use the big bearing spindle as well. EDIT: http://www.pirate4x4.com/forum/showthread.php?t=251126 Last edited: May 28, 2004
