dana 44?
XJjosh
NAXJA Member #1025
USA
i have an xj dana 44 rear end. it has the 5 on 4.5 inch pattern. is there any way i can get new axles/rotors with a 5 on 5.5 inch pattern? maybe from a cj dana 44? it will go with my HD warn 5 on 5.5 inch hub conversion. also, for the dana 30 front end, all I need for the high steer setup is a passenger side knuckle from a WJ right? or do i need both sides? and where would i go for the steering components (drag link, etc.)? thanks.
-josh
you can get some custom shafts and then some nice disc brakes from say, a wj
get rid of the 30 front
