Dana 44 Front High Pinion, all new parts ready to swap in
RWKHausSupply
Dana 44 High Pinion HD housing.
All New:
*3" thick tubes pressed in
*Inner TJ/XJ Knuckles/C's are welded on with lower gussets
*Ball Joints
*Inner seals
*TJ/XJ Thick Currie Brackets installed with Currie Johnny Joint upper mounts
*Premium Gear set (any typical ratio you desire)
*Full bearing kit and install kit
*gears professionally installed
*Yukon Locker installed
*Currie Custom length Inner axles
*U-Bolt style Yoke and u-bolts
Only seasoned item is the center section which is hot tanked, steel abraded, and checked. FULL assembly looks brand new and all but the center chuck, is brand new.
Simply swap over your outer stuff and bolt it in.
2400$
Can add any options in place of an item or additional items at your build desire.
This Housing is over twice the strength of the TJ rubi front D44. Its a high pinion which is better for many reasons, the tubes are easily 3 times stronger than the thin small OD TJ stuff, and the inner C's are gusseted.
Robert
714-875-2414
