Menzenski
Formerly Mambeu
I bought these axles about two months ago intending to put them under my XJ, but have realized that I'm not ready to move up to half-tons yet. The axles are out of a 1979 full-size Bronco. Front axle is complete rotor-to-rotor with radius arms (including frame brackets), drag link, tie rod and trackbar, and 3" lift coils. Rear is complete drum-to-drum. Both axles have a 3.50 ratio. The Bronco these axles came out of was mainly used as a plow truck, so the axles are in pretty rough shape. I wouldn't recommend using them in their current condition, but if you're going to be replacing gears, u-joints and such you'll be fine (the housings are solid). Located in Ithaca, New York. The axles are pick-up only.
$250 for the pair or best reasonable offer. I need to get these out of my driveway.
