badazzcherokee3
- California
Ok Ive got a Dana 300 trans case I want to no will it bolt right up to my transmission or do i have to buy an adapter i have a 1990 jeep cherokee with the 4.0l and the automatic
badazzcherokee3 said:Ok Ive got a Dana 300 trans case I want to no will it bolt right up to my transmission or do i have to buy an adapter i have a 1990 jeep cherokee with the 4.0l and the automatic
jefftrucker12 said:if u want to do the double t case with a driver side pumkin would u have to get a flip kit? im just curious becaue i have a d300 that a friend gave to me and its sitting in my garage taking up room.
opracer315 said:and have some thing to carry the weight of the 300.
opracer315 said:I have done the 231/300 from D.D Machine (4X4 Machine) http://www.pirate4x4.com/forum/showthread.php?t=451754
I had to flip the 231 to pass side drop and flipped the 300 to driver side drop. Used D.D. Machine flip sticks, stock lever with a cable to the 231. Be prepared to do some floor work and have some thing to carry the weight of the 300.
vetteboy said:At this point I'm thinking that this is probably overrated.
I'd like to see what you did though.
Israel said:I'd like to see pictures of your lever/cable setup if you have any!
opracer315 said:Only have a couple of pics. I first used a B&M cable from Summit Racing. But it is a solid core cable which broke after a couple of test tries. I then went to a rigging company I use to work for. They made me a much better stranded cable for the same price as B&M's cable.
This is the cable from Summit. I used the 4' one
http://store.summitracing.com/egnsearch.asp?N=400004+309144+115&autoview=sku
Here are pics of how I attached to the shift lever and t-case lever.
I just looped the cable to the top of the tranny and zip tied it to the wire bracket that holds the knock down cable.
