RWKHausSupply
- yorba linda, Cali
I bought a almost all stock 98 Jeep TJ that has (being removed) a D30 low pinion that also has a ARB. Jeep is a motorhome jeep that was pulled everywhere before I got it. It appears to have some dirt on it, but thats about it.
Will give you everything connected to it as it sits in the jeep.
Complete rotor to rotor, calipers, steering, trackbar, control arms, diff cover. Everything between.
875$ as listed.
1000$ with gear ratio change to 4.11, 4.56 or 4.88.
This is a direct bolt in to a XJ. YES it is low pinion though. So if its a late model with a low pinion its very direct bolt in. If you have a earlier model (most) with high pinion, then you would just need to verify driveshaft length. Should be fine though.
It is in a Jeep that just sits in the driveway right now. And can be removed at most anytime with a day or two notice.
Located in Yorba Linda.
Robert
875$ as listed.
Robert
