Dana 30 front Complete Everything, with ARB
RWKHausSupply
I bought a almost all stock 98 Jeep TJ that has (being removed) a D30 low pinion that also has a ARB. Jeep is a motorhome jeep that was pulled everywhere before I got it. It appears to have some dirt on it, but thats about it.
Will give you everything connected to it as it sits in the jeep.
Complete rotor to rotor, calipers, steering, trackbar, control arms, diff cover. Everything between.
875$ as listed.
1000$ with gear ratio change to 4.11, 4.56 or 4.88.
This is a direct bolt in to a XJ. YES it is low pinion though. So if its a late model with a low pinion its very direct bolt in. If you have a earlier model (most) with high pinion, then you would just need to verify driveshaft length. Should be fine though.
It is in a Jeep that just sits in the driveway right now. And can be removed at most anytime with a day or two notice.
Located in Yorba Linda.
Robert
I'll be watching for deals like this come tax time.
Ok how about 800$...
someone come get it tomorrow for $700. it is out of the Jeep and ready to go.
As it sits
650...
Arb can be swapped to a high pinion. Shafts and brakes can be swapped over to.
3.73, sorry. Just looked and seen that I didnt list that.
$500$
SOMEONE COME GET IT!
Looks to be but idk.
Robert is a pretty good size guy with I'm sure a matching appetite.
Maybe He'll meet ya halfway if you buy lunch.
