Dana 30/free or bring me a beer!
harrahs23
escondido ca
Last time I'm gonna post this then the axle meets the recycle yard. I pulled this out of my 96XJ and it's a high pinion non disco. The reason I pulled is due to it possibly being bent. No carrier or shafts. I also just installed some heavy duty lower control arm mounts with skids that didn't even see the dirt.
It's not bent for sure. I had absolutely zero issues with the axle before installing gears, locker, and chromo shafts. After all that was done it's started popping. I'm over it and want it out of my garage. Located in north county SD.
I'll try and pull it out tomorrow for a pic. I wheeled this axle through all BB without any issues until the mod bug bit and all he'll broke loose. I'd rather see someone use it then just junk it.
