dana 30 disconnect
yellowcj5
what is the cheapest way to permanently connect a disconnect axle. i don't want to fork over $200 for a posi-lok for a $500 MJ.
Open it up, put in about 11 washers, and close it up.
Permanently connected.
When you open it up, you'll see what I mean. Pull off the e-clips that hold it together, and just shim the fork over until you are in the fully-connected position. It is as easy as that.
connect a disconnet axle
If you do this, won't you have problems with your steering? I am going throught this right now, with my shift fork not disengaging the two axle pieces when in 2wd and my steering is very erractic on sharp turns.:confused:
Re: connect a disconnet axle
Locking the shift fork should make the axle functionally equivalent to a 91-up axle, which has no disconnect. If the steering is erratic, I'd suspect something else is wrong - perhaps bad universal joints.
