Dana 20 twinstick fabrication
82scrambler
Anchorage
I checked the archives and found no topics. I fabbed my own twinstick but am in search of a better design hopefully with bushings or bearings involved but not totaly nessesary.
If someone knows of a link for details on this please let me know.
If you can find a Scout with a D20 twin grab that. It just a matter of two bolts & the shift levers that make the twin stick.
Check WWW.AnytingScout.com in Northern Cal, I bought a bunch of parts from Scott when I was building my Scout..
Also check with Boarder parts in San Deigo Ca, he has pretty much everything for the D20's as well.. Good luck
Thanks dude, one problem I live in Anchorage Alaska and its like another country to you guys in the lower 48 and they charge you up the *** in frieght charges so I just would rather fab one of my own and have the gratification that goes along with it.
You could get everthing you need from http://www.mcmaster.com/. they have the nylon or brass bushings as well as push pull cables and levers, rod ends and levers. If you plan out the design you can get most everthing ordered from one place at the same time and save on shipping.
I used an old set of brake/clutch peddles for my twin stick. They already had the bushings and bracket I just cut the actuall peddles off and modified the arms.
