It's a bolt-in swap, but the 8.25 has a longer pinion so if your XJ is not lifted you should get the driveshaft along with the axle (assuming you both have the same tranny and transfer case setup). If you have some lift, the longer pinion will probably make up the slip spline engagement you lost due to the lift.
