D30 shaft change with ARB
brandon350
New Jersey
Quick question, I've been searching but can't find any info.
I recently had a shop install ARB air lockers and 4.88 gears in my C8.25 and D30. When I blow the shafts/u-joints, is the replacement process the same as stock, or will I have to fiddle around in the diffs?
Thanks,
Brandon
Thanks for the reply. I just wasn't sure if the lockers themselves would keep the shafts from sliding out like they did stock. Since I had a shop do the diff work, I'm just having trouble visualizing how everything comes together in there.
The rears are the same regardless in an 8.25... I hope you boughts 30 spline if you spent the coin on an ARB for the D30 (no need to answer). Just make sure of your front spline count, the installation itself is unchanged.
