shmoken875
- Blacksburg VA/ Bel Air MD
Couldn't edit my old thread, and found a bunch more stuff, if a moderator would like to delete the old one that would be fine.
All in Bel Air, MD right now but most can be shipped, some pics available upon request. PM me if you're interested.
98 29 spline chryco 8.25: empty housing-$15
Powertrax 8.25 29 spline locker: about 2 years old-$200
8.25 29 spline spare shaft: $40, 3 available
8.25 29 spline conversion: 29 spline carrier and spiders-$30; with (2) 29 spline shafts $75
8.25 u-bolt yoke: $5
Spidertrax wheel adapters: (2) 5x4.5 to 5x5.5, 1.25" thick, just over a year old-$50
1979 HP Dana 44: out of a F-150 (cast wedges), 3.50's, great condition, no shafts/knuckles/stuff, just axle and gears-$60
44 driver side high steer knuckle w/studs: $50
44 cover: has dent-$5
44 stock lock outs: $15
44 (ford) hub/rotor assembly: 5 on 5.5-$40 for both
44 radius arm: 1 arm, 2 caps, no hardware-$5 for all
44 spindle nuts: 2 sets (inner, outer, and lock ring)-$5
44 high steer arms: pass side has 2 holes for joints, all 3 reamed for GM 1 ton, never used, built in 10* correction. Made by jeepxtremes.com -$100 (these are currently in Roanoke, VA)
98 HP Dana 30: has Alloy USA exterior axle seals, trackbar drop bracket, banged up pretty good, no gears in it (has yoke), has ball joints with less than 6000 mi on them (includes knuckles)-$50
30 brake calipers- good condition, include banjo bolts-$10 each
9" disc brake brackets: nissan maxima parking brake equipped calipers were used with it, zuk 5x5.5 discs included-$10
9" stock yoke: $5
9" stock carrier: $10
9" stock pinion support: $10 (not daytona style)
xj stock shackles: free
xj rim: $5, you take tire too
zj surepull tow hitch: 2" 4000lb hitch-$30
9" stock yoke: $5
