depends on what setup you have. one setup bolts the caliper to the knuckle and the other bolts the caliper to a bracket which bolts to the knuckle. if you have the kind with the seconday bracket and you need the bolt that holds the bracket to the knuckle you're screwed, start looking at the junkyard or go to the dealer.
just to clarify the part number I posted is for the bolts that hold the caliper itself to the knuckle. the other setup is called the "teves" brake setup and uses a bracket between the caliper and the knuckle itself.
